353 Getriebewelle 1974 limo
eoi2621
Mein(e) Fahrzeug(e): 1974 wartburg saloon 353
Ungelesener Beitragvon eoi2621 » Sonntag 16. April 2017, 11:08
Hello Getriebewelle Trommelbremse identisch/anders Getriebewelle
Scheibenbremse.
Hello sorry about the bad german . Are drum and disc brake drive-shafts the same ? Also where can i buy them? Danzer/LDM don't seem to sell drive -shafts . My steering wheel shakes/vibrates when i accelerate at low speeds and i think my drive shafts are worn. Is this correct Thanks
frankyracing
353. So what...
Re: 353 Getriebewelle 1974 limo
Ungelesener Beitragvon frankyracing » Sonntag 16. April 2017, 18:34
Hi,
it could be happen, that you have lack of grease / oil in the drive shaft joints.
Please try as following:
At the inner joint (Gearbox):
- press with two fingers around the collar, to put the grease into the joint
At the outer joint:
- try the same if it's filled with grease (not original, but frome time to time done) :smile:
- if it's filled with oil, check the collars for leaks
Any more questions, please ask.
www.kurbelwellen-richter.de
Ungelesener Beitragvon Warre 1000 » Sonntag 16. April 2017, 19:03
Properly it is the missing grease in drive shaft joints as Frankyracing already discribed. I assume you have had the frontwheel balanced. Here I found a place who sells drive shafts for Wartburg 353W
http://www.ostmobile-shop.de/epages/614 ... 167&Page=3
Of course the problem may be something else.
eoi2621
Ungelesener Beitragvon eoi2621 » Sonntag 16. April 2017, 19:09
Thank Someone on english forum also said to add new grease so i will buy grease gun on tuesday and try that . Thank You
Ungelesener Beitragvon Tomtom » Sonntag 16. April 2017, 20:27
Normally the shaft is not defective.
But the joint which points into the gear box
Dreifingergelenk oder Zapfenstern
https://www.google.de/search?q=zapfenst ... 02&bih=629
You could also have a look on Peters Homepage:
http://www.wartburgpeter.de/tf_fahrwerk16.htm
eoi2621
Ungelesener Beitragvon eoi2621 » Sonntag 16. April 2017, 22:01
Thanks again Danzer sell the inner joint .http://www.danzer-autoteile.de/wartburg ... welle.html BUT they all look the same ? Why three types. How do i know which to buy?
frankyracing
353. So what...
Ungelesener Beitragvon frankyracing » Sonntag 16. April 2017, 22:40
Hi,
the only way is to dismantle the drive shaft :eek: , because of the the fact, that all of these pieces are useable in one car, you have to put the shaft out. -roll-
If you have a bit more experience, you can move the collar to the side of the gearbox and check which dovetail do you have at the end of the drive shaft.
Sorry for these answer, but it is wat it is... {smoker}
Enjoy...
